Hur uppdatera dimage 7i
- Trådstartare Norrbild
Arleklint
Filerna skall ligga på minneskortets "root". Alltså inte i någon av kortets foldrar.
Du skall bara kopiera dit filerna. Inte det bibliotek de låg i när du packade upp din zip.
Har du hittat beskrivningen av tillvägagångssättet på nätet? Om inte följer en beskrivning här. Följ den exakt!
Om det ändå inte funkar:
http://www.fotosidan.se/forum/showthread.php?s=&threadid=4892#post48386
Minoltas info:
DiMAGE 7i v110e Firmware Update
Comments:
DiMAGE 7i Camera Firmware v1.10e
This section explains how to install DiMAGE 7i firmware version v1.10e. (Firmware is software used internally to control the camera.) Be sure to read through the following explanation before you install the software. Do not turn the camera OFF during installation; doing so could damage the CPU inside the camera.
Contents of update
The problem that the camera freezes by the following operation has been corrected.
Setting :
Select EVF auto ON in the setup mode.
Operation :
1) Look through the EVF and press the shutter-release button.
2) Take off the face from the camera and push the QV/Delete button. The last captured image will be displayed on the LCD monitor.
3) Press the magnification button to enlarge the displayed image.
4) Press the Menu button or the shutter-release button partway down to return to the normal display.
5) Press the QV/Delete button again. The camera freezes.
Target products
This firmware is for use only with the DiMAGE 7i and cannot be used with other products.
If the firmware version is already Ver.1.10e , it is not necessary to update the firmware. (Use the following method to check the firmware version.)
This firmware is intended for versions ending with the letter [ e ]. The update does not work correctly if it is installed in other products.
Checking the firmware version
(1) Set the main switch/mode dial of the camera to the setup position.
(2) Press the digital-subject-program button.
(3) Check the number displayed in the LCD monitor display of the camera.
(4) Products with version numbers other than Ver.1.10e are eligible for a firmware upgrade.
Preparing the compact flash card for updating
Use one of the following methods to prepare a CompactFlash card to update the firmware. Format a 4 MB or larger CompactFlash card in the camera. Using the USB cable, connect the camera with a CF card inside to your computer. If the camera is not compatible with the computer system, a CF card drive connected to your computer can be used instead.
The downloaded file is compressed.
1. After creating a folder in your PC and extracting the contents of the archive, the following files are created.
DSC.APP DiMAGE 7 Firmware
RAM.BIN Software for update.
After extraction, copy the files named "RAM.BIN" and "DSC.APP" into the root directory of the CompactFlash card.
2. Before removing the CompactFlash card, confirm that the two files have been copied.
3. Remove the CompactFlash card from the camera or disconnect the USB cable from the camera. If you are using Windows Me, 2000 or XP, click the unplug-or-eject-hardware icon in the lower right-hand corner of the screen, wait until the safe-to remove-hardware window appears, then remove the CompactFlash card from the card reader, or disconnect the USB cable from the camera.
How to update firmware
Note:
When performing the firmware update, use a set of fully charged Ni-MH (nickel hydrogen) batteries or an AC adapter AC-1L or AC-2L (sold separately). When you use an AC adapter, be sure not to inadvertently disconnect the camera during the firmware update procedure.
(1) Insert the prepared CompactFlash card into the DiMAGE 7i, and press the shutter-release button with the main switch/mode dial at the OFF position.
(2) Holding the shutter-release button down, set the main switch/mode dial to the recording mode position.
(3) The access lamp lights for a short period, around two minutes. (You can release the shutter release button after the access light is lit.)
(4) When the access lamp goes out, the update procedure is completed. Remove the batteries, then re-insert it. If you are using an AC adapter, disconnect the AC adapter and/or remove batteries if any inside as well.)
(5) As described above, check the version number displayed on the LCD monitor display. If the number has changed to Ver.1.10e, the update was performed successfully.
* If update was not performed correctly, or an error occurred during the update procedure, turn off the power of the camera, then proceed from Step (1) again.
* Before you use the Compact Flash card for storing image data, first format it again in the camera or delete the two files.
* Windows and Windows Me, 2000 and XP are registered trademarks of Microsoft Corporation in the U.S.A and other countries.
* Macintosh is a registered trademark in the U.S.A. and other countries.
For questions or comments about this matter, contact your nearest Minolta service facility.
Minoltas info:
Comments:
Contents of update
Setting :
Operation :
Target products
Note:
Arleklint
Man säger att man rättat en bugg i den text jag klippte från Minoltas sida. Jag, Kim och många användare på utländska forum noterade dock en snabbare AF.
Jag mailade Minolta och frågade och fick då beskedet att förbättrad AF var huvudorsaken till den nya releasen.
Alltså:
- Rättning av felaktigheter i programvaran som kunde låsa kameran
- Snabbare autofokus
Alltså:
K Lindström
_____________________________________
Jag har provat o provat..
Det jag gör är att hålla ner Shuttern samt vrider till recording.
Lampan lyser ca 1sek sen blinkar den..
När skall jag släppa ?
Håller jag kvar som dom säger ca 2min så händer inge mer sen..
Jag e nog en av dom trögaste personerna på detta område
Och "Lit" ?? vad betyder det.. ??
Tacksam för svar till en trög en..
eatfrog
Du kan släppa när lampan börjar lysa.
När lampan inte längre lyser så är updateringen klar. Ta ur batterierna och sätt in dom igen.Kent_L skrev:
Lyser, när lampan lyser alltså.
/Henri
K Lindström
Tack för snabbt svar..
Men...
Nu är det så att lampan blinkar o blinkar...
Hur länge ska den blinka ?
För mina batterier räcker inte till tydligen.
Och jag har inte någon nät adapter till kameran.
Men...
