Nu är det 100% säkert att en D300s kommer, för nu har Nikon USA (som förväntat) tätat "läckan" och ersatt med skärmdumpar från D5000. Dom är för sköna...
VAD RYKTENA SÄGER:
--> Media Type I CompactFlash (UDMA) & SD (SDHC)
Dual card slots:Either card can be used as the primary card
Secondary card can be used for: a) overflow storage, b) backup storage, or c) separate storage of NEF + JPEG
Images can be copied between cards
--> "Q" (quiet shutter-release)
--> Frame advance rate with EN-EL3e: ~1-7fps (CL), ~7fps (CH)
With MB-D10 + EN-EL4a: ~1-7 (CL), ~8fps (CH)
Self-timer Can be selected from 2, 5, 10 and 20 s duration
--> HD-video, 1280x720 @ 24fps, 640x424 @ 24fps, 320 x 216/24 fps
File format AVI, Compression format Motion-JPEG
Contrast-detect AF on a desired point within a frame is possible (Tripod mode)
Audio can be recorded via built-in or optional external microphone; sensitivity can be adjusted
Stereo mini-pin jack (3.5mm diameter)
Maximum length 5min (1280x720 px), 20min (640x424 & 320x216 px)
