Jepp, det var ett bra tag sen dessutom. Snart ett år sen.
Här är lite citat från Tech Pub'en:
http://www.kodak.com/global/en/professional/support/techPubs/p255/p255.jhtml)
"These films produce high-quality pictorial negatives when processed in KODAK TECHNIDOL Liquid. (See "PROCESSING".) Conventional developers generally produce contrast too high for normal pictorial photography. Process the film according to the instructions for KODAK TECHNIDOL Liquid Developer."
"Technical Pan Film has reasonably uniform spectral sensitivity at all visible wavelengths out to 690 nanometres (nm). Because of this extended red sensitivity, red areas and flesh tones may appear lighter than they would with conventional black-and-white films. This is often an advantage. For example, it helps conceal some skin blemishes and often adds a pleasing luminous quality to skin tones. (This effect is less evident in portraits made in the shade outdoors, because there is less red light present.)"
Vore kul att prova filmen, men den är förbannat dyr, behöver specialframkallare och, ptja, jag behöver inte dendär extrema upplösningsförmågan egentligen. Ska prova en rulle Gigabitfilm under sommaren och se om det är nåt att ha. ;-)
/Henri
