Kortkommando
- Trådstartare Lasse H
Lasse H
Lasse H skrev:
I ps 5,5 kommer jag ihåg att det fanns ett kortkommando Ctrl+å alternativt Ctrl+ä som flyttade upp respektive flyttade ner aktivt lager ett hack i lagerpaletten.
Kanske minns jag fel men jag tror det var så.
Någon som vet om något liknande kommando finns i Cs ?
mvh
Ingen som har svar på denna fråga?
müsli
Gå in i hjälpen
Titta i index (key eller tangent eller kortkommando)
Kortkommando för lager i engelska versionen:
Load layer transparency as a selection
Control-click layer thumbnail
Command-click layer thumbnail
Merge visible layers
Control + Shift + E
Command + Shift + E
Create new empty layer with dialog
Alt-click New Layer button
Option-click New Layer button
Create new layer below target layer
Control-click New Layer button
Command-click New Layer button
Activate bottom/top layer
Shift + Alt + [ or ]
Shift + Option + [ or ]
Select next layer down/up
Alt + [ or ]
Option + [ or ]
Move target layer down/up
Control + [ or ]
Command + [ or ]
Merge a copy of all visible layers into target layer
Control + Shift + Alt + E
Command + Shift + Option + E
Merge down
Control + E
Command + E
Bring target layer to back/front (or back/front) of set
Control + Shift + [ or ]
Command + Shift + [ or ]
Pass through blending mode for layer set
Shift + Alt + P
Shift + Option + P
Copy current layer to layer below
Alt + Merge Down command from the palette pop-up menu
Option + Merge Down command from the palette pop-up menu
Copy all visible layers to active layer
Alt + Merge Visible command from the palette pop-up menu
Option + Merge Visible command from the palette pop-up menu
Copy visible linked layers to active layer
Alt + Merge Linked command from the palette pop-up menu
Option + Merge Linked command from the palette pop-up menu
Show/hide this layer/layer set only or all layers/layer sets
Right-click the eye icon
Control-click the eye icon
Show/hide all other currently visible layers
Alt-click the eye icon
Option-click the eye icon
Toggle lock transparency for target layer, or last applied lock
/ (forward slash)
/ (forward slash)
Edit layer effect/style, options
Double-click layer effect/style
Hide layer effect/style
Alt-double-click layer effect/style
Option-double-click layer effect/style
Reveal/hide all layers and effects
Alt-click layer set expansion triangle
Option-click layer set expansion triangle
Edit layer style
Double-click layer thumbnail
Disable/enable vector mask
Alt-click vector mask thumbnail
Option-click vector mask thumbnail
Toggle vector mask on/off
Shift-click vector mask thumbnail
Open Layer Mask Display Options dialog
Double-click layer mask thumbnail
Toggle layer mask on/off
Shift-click layer mask thumbnail
Toggle between layer mask/composite image
Alt-click layer mask thumbnail
Option-click layer mask thumbnail
Toggle rubylith mode for layer mask on/off*
\ (backslash), or Shift + Alt-click
\ (backslash), or Shift + Option-click
Select all type; temporarily select type tool
Double-click type layer thumbnail
Create a clipping mask
Alt-click the line dividing two layers
Option-click the line dividing two layers
Rename layer
Double-click the layer name
Create new layer set below current layer/layer set
Control-click New Layer Set button
Command-click New Layer Set button
Create new layer set with dialog
Alt-click New Layer Set button
Option-click New Layer Set button
Create layer mask that hides all/selection
Alt-click Add Layer Mask button
Option-click Add Layer Mask button
Create vector mask that reveals all/selection
Control-click Add Layer Mask button
Command-click Add Layer Mask button
Create vector mask that hides all/selection
Control + Alt-click Add Layer Mask button
Command + Option-click Add Layer Mask button
Display layer set properties
Right-click on layer set
Control-click the layer set
Display layer options§
Alt + double-click layer thumbnail
Option + double-click layer thumbnail
Select/deselect multiple contiguous layers§
Shift-click
Shift-click
Select/deselect multiple discontiguous layers§
Control-click
Command-click
Control + Shift + E
Command + Shift + E
Alt + [ or ]
Option + [ or ]
Control + [ or ]
Command + [ or ]
Merge down
Control + E
Command + E
Shift + Alt + P
Shift + Option + P
/ (forward slash)
/ (forward slash)
Edit layer style
Rename layer
Shift-click
Shift-click
Control-click
Command-click
Lasse H
Control + [ or ]
Command + [ or ]
Hur gör jag detta på mitt tangentbord?
Jag måste hålla ner AltGr för att komma åt ([) eller (])
Estethia
Lasse H
Re: Varför inte skapa ett eget komando?
Yes, nu funkar det.
greggan skrev:
Gå in under mneyn Edit/Keyboard shortcuts
och skapa ett eget eller modifiera befintliga
komandon!
Yes, nu funkar det.
- 7 K
- 5 K
