dagr
http://www.canon-asia.com/index.jsp?fuseaction=support&prod_type=dc
Här är texten till Windows-versionen:
Overview
Digital Photo Professional 1.5.0 is software exclusively for editing and converting RAW images shot by EOS Digital cameras.
Users of EOS Digital cameras can install Digital Photo Professional 1.5.0 by downloading Digital Photo Professional 1.5.0 Updater for Windows.
Important
1. This software is exclusively for Windows XP/Windows 2000.
2. Before downloading Digital Photo Professional 1.5.0 Updater for Windows please make sure that if any of the applications listed below are installed on your computer.
- File Viewer Utility 1.1 to 1.3
- EOS Viewer Utility 1.0/1.1
- Digital Photo Professional 1.0/1.1
- RAW Image Task 1.2
3. To use the remote shooting function in Digital Photo Professional 1.5.0, you need download and install EOS Capture 1.2.0. (Must be downloaded separately.)
Digital Photo Professional 1.5.0 is not compatible with EOS Capture 1.0.0. Please download the new EOS Capture 1.2.0.
Changes
Changes in Digital Photo Professional 1.5.0 from the previous versions (Digital Photo Professional 1.0/1.1) are as follows:
1. An image trimming function has been added.
2. A simulation function has been added for CMYK printing. Selecting the profile to be used for printing ensures that the colors displayed in the [Preferences] windows and used for printing conform to the selected profile. This allows you to check beforehand how the colors will look when the image is printed using CMYK.
However, the profile specified in this function is not applied when Easy-Photo Print is used for printing.
3. It has become possible to transfer multiple images to any retouching application with a single operation.
4. In the main window Tree View Area, folders can be copied, moved, and deleted.
5. The tone curve in the [RAW images adjustment tool palette] has changed to a log display.
6. Printer profiles can be specified in the [Color management] tab of the [Preferences] dialog box.
7. When saving an image file, the image size can be set in the [Save as] dialog box.
8. If you select the [Help] menu, and then click the [Digital Photo Professional Help], Digital Photo Professional Instruction Manual will be displayed in PDF format.
9. When saving an image in JPEG format, an ICC profile can be embedded in the image using the [Save as] dialog box.
10. When saving an image in TIFF format, sharpness settings for the image can be changed in the [Save as] dialog box.
Overview
Important
Changes
