irrbloss
Kunde tyvärr inte se den, får bara hem 85 KB av filmenOch så här ser det ut med en RED One. Filmen är helt inspelad med RED One och kameran kan knappast kallas semiproffs. De har precis annonserat en ny liten zoom, 18-85/T2,9 som väger 4,5kg och kostar $9975. Täcker ungefär samma bildcirkel som en EF-S från Canon =)
När det gäller hastighet i att ställa om sensorn för en ny bild (kameran klarar 120FPS), så spelar RED i en helt annan division än sensorn i 5D MkII.
Performance issues
Like many CMOS-based cameras, images captured by the Red One show rolling shutter artifacts. These occur because data is read from the sensor line by line over a short period of time, rather than all at once, so each frame in an image sequence does not actually represent a single instant in time. Rolling shutter artifacts can cause vertical objects to appear to lean as they move or as the camera pans past them, and can cause strobe effects like camera flashes or lighting strikes to appear only on portions of frames, creating a "tearing" effect. Also, in some shots with heavily overexposed highlights (often seen when the camera is pointed into the sun, for example), the brightest parts of highlights are rendered as purple or gray (one would expect them to be white). This is apparently related to some sort of self-protection feature in the sensor. Red has indicated that they are working on resolving this issue.
Källa: http://en.wikipedia.org/wiki/RED_Digital_Camera_Company
