lottawe
Sökte lite för jag vet att jag både läst på webben, (men även på andra platser.)AFE skrev:
Jag tror inte att man under några omständigheter tjänar på att flytta tyngd till objektivet (oavsett stativ och objektiv), om det inte är så att man har så mycket glapp i stativlösningen att det gör att det glappar mindre ...
Hittade tyvärr inte så mycket men iaf:
"If you can't afford a gimbal, there are less expensive methods to stabilize the camera on the tripod. Drape a jacket over the camera or place a beanbag on top of the lens. This also helps avoid vibration."
Källa: http://www.photofocus.com/showarchive.php?aid=166&cid=4
och..
Tips for Sharper Photographs
* Use the weight hook - hanging a weight from the hook below the head gives your tripod more mass, damping vibration. Make sure the weight doesn't swing however.
* Wrap your hands around the camera - this also dampens vibration (but shoot inbetween heartbeats
* Use the MLU (mirror lock unit) to prerelease the mirror, and wait 10 seconds before releasing the shutter
* Use a long cable release or self-timer to minimize vibrations
* Use the stiffest tripod/ball head combination that you can carry (composites are better at damping vibrations)
* Place a bean-bag on top of your camera or longer lenses
* Support longer lenses with another tripod or tripod extension arm
* Use a "tuned" tripod with stiff metal spikes (titanium) and vibration-absorbing base (although these increase the moment arm)
* Use image stabilized lenses (some work on tripods)
Källa: http://www.websiteoptimization.com/speed/tweak/ballhead/
