Vad är detta?
- Trådstartare Sir Hans
PatrikPolly
Min far har ett sådant till sitt tamron 80-250mm 3,8 (pentax fattning). Blir lite stabilare.
Kunde nog inte ändra fokus med avtryckaren dock.
Janne.B
Det där är vad jag kan se en zenit photosniper utrustning....
http://cgi.ebay.com/ws/eBayISAPI.dl...loc=closed_view_item&refwidgettype=osi_widget
Melker Humala
chrahl skrev:
Tror att de är ett teleobjektiv med snabbfocusering via avtryckaren. Har sett liknande tidigare, men minns inte vilket fabrikat det var på objektivet. Någon som kommer ihåg?
Tänker du på Novoflex:
http://www.novoflex.com/english/html/lenses.htm
Svedlund
FS-12-1, 1982-1990 Based on a modified Zenit 12 (which was a new version of the Zenit TTL) called Zenit 12S.
Tair 3S 300mm aluminum casing. (new casing version)
FS-12-1 seems to have ended around 1986.
FS 12-2, Based on a modified Zenit 12XP called Zenit 12XPS (full metal camera) needle meter has been replaced by a 2 led system.
Tair 3S 300mm Leatherlike case/aluminum casing.
FS-12-2 seems to have ended around 1988/1989.
FS 12-3, Based on a modified Zenit 12XP called Zenit 12XPS but later version with plastic topcover for the camera.
Tair 3S 300mm Leatherlike case.
FS-12-3 ended around 1990.
Standard lens in the case, Helios 44-4 or 44m-4 58mm/2.
110.000 of FS-12 series were produced. This could be the most produced Sniperset. Also this set is considered to be one of the finest and best Snipersets ever made.
Several minor variations in text exist. All units came in black. Some came in all metal later ones came with the topcover in plastic. The Tair 3s has an open aperture metering system which connect to the 12's body by means of a cable. (On ALL FS-12 Series) Latin and Cyrillic versions exist.
http://www.xs4all.nl/~tomtiger/index.html
se sedan i menyn "The Photosniper"
- 1 K
