zatopek
Hittade detta trick på ett malaysiskt forum. Vet inte om det fungerar, då jag inte har en D300 (ännu).
<quote>
"You just need to set E5 and E6 to flash only, don't pop up the flash, set the exposure to "M" and the release mode to "S" (single shot), activate bracketing and set it to 9F. Then you hold the bracketing button (normally mapped to the function button) down and at the same time the release button. The 9 shots (all with the same exposure you have manually selected) are fired at 8 frames per second instead of the normal 6 fps. After the 9 shots you have to release and press again the shutter button to get additional 9 shots."
Of course, this cannot replace the BG which is the way to true auto 8fps & better balance. But, i personally think, it has some uses, albeit very limited.
</quote>
/Mats
<quote>
</quote>
/Mats
