Jonas Nylund
Sagt av Nikon-gurun Thom Hogan, http://www.bythom.com/105AFSlens.htm
"The exact words in the Nikon manual say "As the reproduction ratio increases from 1/30x [sic], the effects of vibration reduction gradually decrease." In other literature, Nikon has flat out said to turn off VR for macro use. What's the real answer? The manual is correct, basically. The closer you focus, the less VR has an impact on the final image. At 1:1 (the closest focus distance), it may not impart any benefit (it didn't seem to in the testing conditions I could create)."
Alltså kommer bildstabiliseringen att "skaka" bilden istället för att stabilisera den? Är det kanske därför man ska stänga av den när man har kameran på stativ också?
