Batteri till Minolta Hi-Matic F
- Trådstartare LOA
decadent
Ett bra ställe för exotiska batterier är
http://www.photobattery.com
Om du inte får tag i 1,4 voltsbatterier som passar hittade jag följande tips:
Make your own battery adapter that can accept the more commonly available SR44/A76 1.5 volt button cells. (The A76's run around $1 each from places like Radio Shack or even local drugstores.) This is how:
All you want is a conductive spacer that makes up for the difference between the dimensions of the small SR44/A76 and the thicker PX640 cell.
My adpater is made from the cap of a Crayola marker. The ridge on the cap is carefully cut off with a sharp utility knife or sanded down. The length of the cap is cut to the dimension needed to fit in the battery chamber of the camera.
A small screw, of the type used on computer circuit boards and computer cases is snug fitted through a hole in the Crayola marker cap. The end of the screw should lightly touch a A76/SR44 cell snug fitted into the cap from the open end. You may need to experiment with different size screws to get it right.
Make two of these and you can continue enjoying the Hi-matic F or E that you have. Make sure the cells are correctly inserted to match the polarity of the battery for the circuit.
I seem to be getting identical metering with PX640A's and my adapters, as indicated by the lens openings. I can't say with certainty about shutter opening times.
decadent
Hej igen. Eftersom jag har ungefär samma problem med min Olympus 35RD har jag forskat lite mera. Eftersom det här är ett "gör det själv" forum passar den här utmärkta artikeln om hur man bygger en batteriadapter väl bra?
http://www.rolleiclub.nl/batt-adapt-US.pdf
Fatherof4
En oändligt gammal tråd. Men är det nån som har färska tips på hur man löser batterifrågan på en Minolta Hi-Matic F?
Inte helt ny tråd, men det verkar som om det finns lite olika batterier som passar: http://www.rangefinderforum.com/forums/showthread.php?t=76952
Lycka till, har själv haft tur när jag köpt några gamla Yashica och hittat passande batterier på Kjell & Company.
olind
Enligt ranegfinderforum kan man använda 2 x SR44 eller 2 x LR44. Läser jag mellan raderna kanske SR44
Fatherof4
Enligt ranegfinderforum kan man använda 2 x SR44 eller 2 x LR44. Läser jag mellan raderna kanske SR44rna är något bättre.
Det är väl bara att prova med de billigaste och se hur bra det blir.
Yonazarith
Själv kör jag på vanliga LR44 och lite metallskrot för att få kontakt hela vägen. De ger ju lite för hög spänning, vilket i mitt fall ledde till för korta slutartider, vilket löses med att överexponera ett steg på ISO-inställningen (dvs kameran inställd på lägre ISO än filmhastigheten). Trevlig liten kamera iaf
olind
Själv kör jag på vanliga LR44 och lite metallskrot för att få kontakt hela vägen. De ger ju lite för hög spänning, vilket i mitt fall ledde till för korta slutartider, vilket löses med att överexponera ett steg på ISO-inställningen (dvs kameran inställd på lägre ISO än filmhastigheten). Trevlig liten kamera iaf![]()
Menar du 1 steg (100 iso -> 50 iso) eller 1 snäpp?
Jag fick tyvärr inget objektivskydd med. Har du tips på var man hittar sånt? Den är 48.3 mm i ytterdiameter.
Yonazarith
Steg, kört 400-film med kameran inställd på 200. Men det bästa är ju att köra en testrulle och se hur den blir efter framkallning.
Gällande linsskydd är det nog lättast att bara leta upp från valfri tillverkare som passar i en 46mm filtergänga, bör finnas i valfri fotobutik för rätt små pengar.
Chr.Bra
Har du två eller fyra LR44 batterier i då?
/ Christer
Yonazarith
/ Christer
Två batterier, annars skulle det bli på tok för hög spänning... sen har jag fyllt ut med brickor och liknande tills det sitter stabilt.
olind
Jag sågade av en blyertspenna i lagom längd och körde runt folie. Den stoppade jag där ena gamla batteriet satt.
På andra sidan la jag 2st LR44or bredvid varandra och dom typ fyller ut hålet. Kanske att man ska lägga nån bricka eller så där också dock.
Vore nice med nån liten ring runt batterierna så de blir samma storlek som dom gamla.
Chr.Bra
Kanske en korkad fråga men funkar det inte att ha kvar ett urladdat batteri som utfyllnad?
/ Christer
- 7 K
