Sten-Åke Sändh
SAR idag 15/11-14:
http://www.sonyalpharumors.com/wp-content/uploads/2014/11/structure1.png
Så här skriver SAR:
" Tech freaks will be happy to see the details of the world first Sony APCS (active pixel color sampling) sensor! The full document can be download here. Be kind note
If that news is helpful for you link back to SAR when reposting, retweet it and like it on facebook. Thanks!
Like I told you a couple of days ago this is a 1.5inch sensor likely to be introduced in early 2015 in some compact device (maybe for the Xperia Z4?). The Sony sensor has the world first sensor capable of capturing the full color spectrum info in one single pixel. Sigmas Foveon sensor used on DP cameras uses three layered RGB pixel ordered vertically but the new Sony sensor has just one single layer. The sensor is also capable of Global Shutter and 2K recording at crazy 16,000 frames per second.
Today I got those detailed graphs showing how the sensor works. “Structure 1″ shows how there is a color filter on top of the sensor that moves horizontally. There are three different exposures for each color (Red-Green-Blue). It’s basically a “color HDR” picture instead of a “dynamic range HDR” picture
Det är väl logiskt att vi får denna typ av sensorhårdvara när dataprocessningen blir allt snabbare och tydligen möjliggör flera exponeringar av varje pixel på bråkdelar av millisekunder. Sedan väntar vi väl på nästa steg då med ett antal HDR-exponeringar ovanpå detta.
. The sky is the limit! - eller hur?
Man undrar ju när de där teknikerna sover eller sätter sig på långbänken och ljuger lite!
Så här skriver SAR:
