deadendveiw
som mitt namn antyder så vill jag ha lite information om nikon d700, jag har just nu en d90 som jag är väldigt nöjd med, men jag känner att jag skulle vilja ha en fullformatare istället. jag ska börja fota i studio och dylikt snart och sånt. men jag undrar hur det är med dx objektiv.
Nikon D700 Key Features
12.1 megapixel full-frame sensor (8.45µm pixel pitch)
Image Sensor Cleaning (vibration) *
ISO 200 - 6400 (with boost up to ISO 25600 and down to ISO 100)
Also supports DX lenses, viewfinder automatically masks (5.1 megapixels with DX lens)
14-bit A/D conversion, 12 channel readout
Same ultra-fast startup and shutter lag as D3
Nikon EXPEED image processor (Capture NX processing and NR algorithms, lower power)
New Kevlar / carbon fibre composite shutter with 150,000 exposure durability *
Multi-CAM3500FX Auto Focus sensor (51-point, 15 cross-type, more vertical coverage)
Auto-focus tracking by color (using information from 1005-pixel AE sensor)
95% coverage, 0.72x magnification viewfinder *
Auto-focus calibration (fine-tuning), fixed body or up to 20 separate lens settings
Scene Recognition System (uses AE sensor, AF sensor)
Picture Control image parameter presets
5 frames per second continuous with auto-focus tracking*
Optional MB-D10 Battery Pack (same as D300), increases burst rate to 8 fps *
UDMA compatible single CF card slot *
3.0" 922,000 pixel LCD monitor
Live View with either phase detect (mirror up/down) or contrast detect Auto Focus
Virtual horizon indicates if camera is level (like an aircraft cockpit display)
HDMI HD video output
'Active D-Lighting' (adjusts metering as well as applying D-Lighting curve)
Detailed 'Control Panel' type display on LCD monitor, changes color in darkness
Magnesium alloy body with connections and buttons sealed against moisture
Improved Info display on main screen *
vad menar dom med att sökaren maskar ner den till 5 pixlar?
