Ola Dyrhill
Är det nån som jobbar i LR på en värstingmaskin och INTE upplever någon nämnvärd fördröjning under arbetet, exv vid bläddring mellan bilderna o liknande.
Jag sitter iofs på en skapligt väl specad macbook men det tycks inte hjälpa, jag tycker att det blir en hel del väntetid i processen med att jobba med bilderna vilket gör att själva arbetet med redigering tar längre tid än vad jag tycker att det borde göra.
Hittade en rekommenderad spec på vad som krävs (inte från Adobe utan från någon annan)
Overview of Recommended Hardware for Lightroom:
Processor (CPU)
*A CPU with a high frequency and a medium number of cores (typically between 4 and 6) should provide the best overall performance in Lightroom.
Video Card (GPU)
Lightroom added limited support for GPU acceleration which means*your video card will actually*have an impact on the performance of Lightroom. We recommend a mid-level video card with 2-4GB of VRAM, but if you also work with large images in Photoshop or use a 4K monitor a 4GB video card is a good idea. Also, if*you will be using a 30-bit monitor, you will need a NVIDIA Quadro video card as GeForce cards currently do not support 30-bit display output.*
Memory (RAM)
We generally recommend 16GB as a starting point if possible especially if you will be working with either high resolution or large numbers of images, if you work with very large images (750MB+) in other programs like Photoshop*you may consider*32GB or even more system RAM. Ideally, you want a bit more RAM than you actually need as it will give you room for growth.
Storage (Hard Drives)
A primary SSD is highly recommended for the operating system and the base Lightroom*installation.
Processor (CPU)
Video Card (GPU)
Memory (RAM)
