vilket minneskort?
- Trådstartare chewie
smedberg
Jag rekomederar dig att köpa ett ultrakort.
Sandisk Ultra 512MB 1369K/sec
Sandisk "standard" 512MB 793K/sec
Du kan läsa mer här: http://www.steves-digicams.com/2002_reviews/d60_pg2.html
256MB lär inte räcka långt på en D60. Jag har en D100 och kör med två 512MB Sandisk. Ska skaffa ett 1GB.chewie skrev:
hej jag undrar vilket minneskort ar lampligast for canon d60? snabbt nog och bra kvalite... vad ar det igentligen for skilnad mellan dom olika. sattsar nog pa ett 256mgb men vet inte vad jag ska titta efter?
inga proffs grejor bara sa jag klarar mig..
Camerans
Yep, I use Sandisk myself and find them most reliable and good quality and many friends of mine wordwide use them. Another one is Lexar. Don't worry too much about the write times (24x, 16x etc..) We did some tests on the different cards and the difference was negligle. In fact, the write time from camera to card was exactly the same on most cards as the camera tested, a Nikon D100, could only write to card at a certain speed anyway, so the times were basically identical. Go figure.
Bests, Duncan
Bests, Duncan
smedberg
"Several D60 design decisions mean that this camera will benefit from the fastest possible CompactFlash card.
First, The D60 is not able to shoot and write simultaneously. Therefore, if you hit the buffer limit when shooting an extended sequence, as often as not you'll need to wait for the camera to finish processing one photo before continuing. The length of time you'll wait is largely dependent on the write speed of the card.
Second, the camera's relatively small 8 frame buffer, regardless of file format, means that it's possible to bump up against the buffer limit in all sorts of shooting situations.
Third, the D60 doesn't permit the reviewing of photos until the buffer is completely emptied to the card.
My strong recommendation is to consider only the fastest cards available for the D60"
Allt enligt www.steves-digicams.com
Hastigheterna jag skrev tidigare gäller D60
Håller med om storleken, minnet äts fort upp om man kör RAW.
smedberg
sa hur manga bilder far plats pa ett 256mgb... raw format?
Jag tror det får plats ca 34 bilder i RAWformat på ett 256mb kort.
Camerans
Hi Thomas.
Not sure about the D60 as I've never tried it. I use a Nikon D1x which doesn't suffer from these problems in the same way, but on the Nikon mailing list and whole bunch of guys got out their D100s and tested different cards they had. The results were suprising.
The review sites are great in some ways and provide alot of useful info. but there's nothing quite like testing yourself to find out what happens in practical reality.
Again, I have no experience of the D60, however.
Well, think I'm going to go out and shoot something! (with my camera, of course
Bests, Duncan
Bests, Duncan
smedberg
Ja, man ska kanske inte tro på allt man läser. Det är bäst att testa själv
Camerans
LOL "Det ha du fan rätt i!!" Ha! Ha! I'm just laughing at our half English, half Swedish converations. I need to start writing Swedish, but I fear that anyone reading it will be reading it with Stuart Baxter's accent, and I'm not sure I like that idea....-grin-
Now, which symbols can we invent to show the dialect being used in emails?
Best, Duncan
Best, Duncan
Vet inte, men på D100 får jag in 51 bilder på ett 512MB kort. Inte mycket, alltså.chewie skrev:
Mr.X
Jag har en Sandisk Ultra 256:a, kortet är helt kanon.. skriver väldigt snabbt. När det gäller storleken så beror det ju självklart på vad du ska plåta; natur, modeller, sport, nyhetsbilder etc etc. De 2 senare (sport och nyhetsbilder) så behöver/ska man ju självklart inte plåta i RAW/TIF sålänge du inte är grymt säker på att du kommer få med hela händelsen i en enstaka bild på 35Mb +. (Chansade på filstorleken där)
/Christian
/Christian
jns
Hastighet...
...kan alla kameramodeller utnyttja de fördelar Ultra korten ger i fråga om skrivhastighet? Jag har ett 128Mb Sandisk vanligt CF-kort och upplever en "rejäl" väntetid då jag använder .TIFF och 6Mp (interpolerat) på min Fuji S602z. Filerna blir på ca 18Mb. Ultra korten skall altså klara dubbla skrivhastigheten... Om jag däremot använder .jpg upp till ca 2.5Mb går det blixtfort.
//Jens
//Jens
bull
Här finns en test på läs och skrivhastighet på olika kort http://www.dpreview.com/articles/mediacompare/
Linmajon
Enligt testet är en 1Gb microdrive nästan dubbelt så snabb som ett Sandisk ultra vid skrivning. Vad säger ni om det?bull skrev:
Intressant, men jag törs inte köra med Microdrive ändå. De flesta säger att de funkar bra, men jag är rätt så klantig, har redan tappat mina CF-kort otaliga gånger, vågar inte drömma om vad som skulle hända om det var Microdrive.Linmajon skrev:
henab
digitalnytt tar 2445:- för en 1gb microdrive.
Överlägset flest bilder per krona, och även om de är ömtåligare än andra CF-kort så faller de faktiskt inte sönder bara man tittar mot dom
Min fungerar bra i alla fall.
- 5 K
- 43 K
