Digi
Hej, vet någon om de föredelarna som finns i Mac versionen av Lightroom kommer in i Windowsversionen senare?
Eller i Beta 4?
Som allt detta som jag vill dra nytta av?
Known Issues for Beta 3
Lightroom Windows beta 3 is feature compatible with Mac beta 3. However, there are some exceptions:
No Web module
No Identity Plates
No Lights Out functionality
No automatic detection of cameras and memory cards for import
No Music for Slideshows
Printing color management is not optimized yet. While your images will print reasonably well, the color may be off
High ASCII and Double Byte support is not fully enabled
General
Lightroom for Windows currently needs to be run from inside an English language environment.
Thumbnail building uses all available processor capacity.
Cannot shift-tab backwards through fields.
Edit Capture Time does not display the date.
Time on files created for Edit in Photoshop is off by 7 hours.
Edit in Photoshop from Lightroom does not show an error dialog if a file cannot be opened. This is caused by having an older version of the Camera Raw plug-in (i.e. Version 3.0x113). Please visit the following link to update the Camera Raw plug-in: http://www.adobe.com/products/photoshop/cameraraw.html
If you have images in a read-only location, Lightroom will not inform you of a failure to write out sidecar files.
Updating of the main window, especially when dragging another window on top of Lightroom, doesn't happen immediately.
Import
To Import PSD files you need to save the file in Photoshop with "Maximize Compatibility" turned on.
Text is cut off on the Shoot popup menu.
8 bit TIFF files with JPEG compression may appear pixilated in Lightroom.
"Progressive" format JPEG files have a black line along the bottom of image.
TIFF files saved as "Packbits" are not supported in Lightroom.
Some layered TIFF files with a top adjustment layer show incorrectly (gray stripes).
CMYK files will not import into Lightroom at this time.
Export
Using a very long filename (i.e., greater than 200 or so characters) in the Export Rename dialog may cause the "overwrite" dialog to come up.
Library
There are cases of excessive redrawing of the UI.
Images may not be in correct time-lapse order in Library.
Slideshow
Exporting a Slideshow to PDF can take a long time, especially if more than 50 images are selected. Don't attempt to use the exported PDF file until the Activity Window is empty. The progress bar on the task erroneously shows 100% complete, instead of progressing while the task is working.
Print
Printing using the Managed by Printer setting can produce incorrect colors at this time
Mvh Markus
Eller i Beta 4?
No Web module
No Identity Plates
General
Import
Export
Library
Slideshow
Mvh Markus
