Vibrance
iBoat
i Aperture finns en funktion som heter "Vibrance", den finns kanske i andra Raw-konverterare också.
Vet någon hur den fungerar? dvs, vilken del av kurvan verkar den i, och hur?
Man kan uppnå riktigt bra resultat tillsammans med "Saturation" på en bild. På en annan bild blir det katastrof trots samma inställningar.
Ett otroligt bra verktyg, men svår att förstå...
Googlade lite;
"Lightroom's Vibrance slider is a more selective version of the Saturation slider. Whereas the Saturation slider increases the saturation of all of the tones in your image, the Vibrance slider limits its saturation boost to primary colors, leaving skin tones and other secondary shades untouched (Figure 7). The result is an image that has what appears to be increased saturation, but without unsightly hue shifts."
Källa:
http://www.creativepro.com/article/using-photoshop-lightroom-part-2
Hittade svaret
Vibrance!
Boosting saturation pumps up the green foliage but blows out the sunlit side of the canyon walls
An identical boost to vibrance though much better targets the areass needing help
Ever since the days of film when Velvia was dominant, nature photographers have known that a little touch of added saturation can make images more compelling. Now, the digital age has given us an even better solution, and it goes by the name of "Vibrance."
An image that is uniformly washed out can benefit greatly by a slight boost globally to saturation. The problem comes though when some areas of an image look fine already while other areas are in need of more punch. For such images, increasing saturation only serves to make them look garish or artificial. Bumping saturation globally enough to improve the problem areas can put the areas that were already saturated enough over the top. And trying to target the change to saturation to only the areas in need can be difficult to control, often resulting in images that look like they've been manipulated.
Vibrance addresses this problem by acting proportionally on areas of an image that need it most. Less saturated areas automatically receive the most attention while parts of an image that already have some degree of saturation are affected less. As an area approaches being clipped, it gets affected less. This lets you more freely boost vibrance in order to improve problem areas without having to worry about blowing out areas that already have color. By appropriately adjusting both saturation and vibrance, you can fine tune the appearance of an image to a degree not previously possible without extensive masking.
As an added bonus, the algorithms used by vibrance are programmed to recognize skintones and prevent them from becoming over saturated. A nice touch for portrait and fashion photographers as well as anyone who has ever shot a birthday party of family get together.
To the best of my knowledge, the concept of vibrance first appeared in Pixmantec's Rawshooter raw file converter. Adobe bought Pixmantec in 2006 and vibrance appeared shortly thereafter in the beta releases of Adobe Lightroom. As of the release of CS3, they've added it to Photoshop as well, but for now only in Adobe Camera Raw 4.
Lite förenklat på svenska.
Med Vibrance ökar man färgmättnaden i dom färger som inte har så stor mättnad. För dom färger som redan har stor mättnad blir ökningen mindre.
Saturation däremot ökar alla färger lika mycket och kan därför "förstöra" en bild.
Vibrance förstör inte hudtoner så som Saturation ofta gör.
