Sten-Åke Sändh
En testare som testar Zeiss/Sonys nya 50mm/1,4 mot Samyangs nya AF 50mm/1,4 svårt att tro sina ögon när denna Samyang slår Zeissen i center, mid och i kanterna. Priset på Zeissen är ca 1500U$ och Samyangen kostar ca 7000$. En del har tyckt att 7000:- för en "no name" normal varit väl högt trots att Samyang nu skickar med AF som saknats tidigare.
http://www.sonyalpharumors.com/big-...s-samyang-50mm-f1-4-fe-surprising-conclusion/
“From the outset, hot, first finding emerges: in all openings, the Samyang leading the debate, with a center always has a better resolving power. The maximum dive is for both goals achieved at f / 8, but again, be it in the center, on the outskirts or in the corners, the Sony lets himself be dominated. Also, on our first tests, vignetting of Planar seems more marked us, which is not necessarily aesthetically unpleasant. Intuition specify when our field tests.”
I am not sure but I think they maybe got a wrong calibrated lens sample from Sony? I find it almost impossible the Samyang can be better than the new Zeiss! Also because just recently Lensrentals said about the Zeiss 50mm FE that “the center sharpness in particular is unheard of in a 50mm lens“. So please take the Lesnumeriques test results with a grain of salt….
(slut citat)
Hmm ... Zeissen måste nog vara felkalibrerad. Lite kul är det allt tycker jag. Den har nog i alla fall bättre bokeh.
(slut citat)
